Colibri PXA320
Colibri PXA320 is an SODIMM sized computer module which is part of the Colibri product family. Colibri PXA320 is based on the Marvell Arm® XScale® PXA320 (Monahans) processor and runs at 806MHz. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology. The module comes with a pre-installed and fully licensed WinCE 5/6 core OS. Linux and Android are also available.
Highlights
Toradex no longer recommends these SoMs for new designs. Please consider alternative SoMs such as our Colibri iMX6 System on Module or the iMX7 System on Module. You will find our entire product Colibri portfolio listed here.
Ready for takeoff - Marvell XScale® PXA320 with 806MHz
The Colibri PXA320 is a SODIMM-sized computer module which is part of the Colibri family of modules. This product is used worldwide, in many critical applications. It comes with WinCE (Windows Embedded Compact) preinstalled. Its pin-compatibility with other Colibri modules featuring the latest SoCs from NVIDIA® and NXP® make it future-proof.
Colibri PXA320 is based on the Marvell Arm® XScale® PXA320 (Monahans) processor and runs at 806 MHz. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology.
Besides the internal Flash memory, there are plenty of interfaces available for data storage: USB-Memory Stick, Compact Flash / PCMCIA and SD Card.
Colibri modules provide glueless connectivity to passive and active LCDs with resolutions of up to 1024x768, as well as four and five-wire resistive touch screens. An integrated 16 bit stereo codec allows to play and record audio. Colibri modules can directly connect to a CMOS camera sensor.
In addition, these modules offer 100 MBit Ethernet as well as USB host and USB device functionality.
Pin-compatible with other Colibri modules
The Colibri family of modules are pin-compatible. This allows you to scale performance and price, and easily upgrade easily to the latest SoCs. Toradex WinCE (Windows Embedded Compact) OS and Toradex Software Libraries abstract the Hardware to make transition as easy as possible. To check if your carrier board is ready for your next Colibri module, use our quick and easy Pin-out Designer tool.
Design your own, use Toradex, or third-party Carrier Boards.
Industrial Temperature
Colibri PXA320 IT is a special version which meets the stringent requirement of industrial temperature range (-40 to +85 °C).
Professional development tools
Colibri modules come with a Windows CE operating system pre-installed. Also, state-of-the-art development tools allow easy customization of the system to make it fit specific needs (e.g. LCD settings & timings, integration of customer software and the auto-start option at startup).
Users can, therefore, concentrate on their actual application without going through the hassle of setting up an operating system. Special drivers are delivered by Toradex on request.
Latest Information on the Colibri PXA320
Operating Systems
Carrier Boards
Accessories
Buy Now
Quantity>0
Unit Price$219.00
In stock
Connectivity: USB 2.0: 1x Host / 1x OTG, 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
Unit Price$54.60$52.45$49.15$46.95
Limited stock
Limited stock
Unit Price$26.60$25.55$23.95$22.90
In stock
Unit Price$32.35$31.05$29.10$27.85
In stock
Quantity>0
Unit Price$61.50
In stock
Fasteners for Colibri modules
Quantity>0
Unit Price$32.50
In stock
Quantity1-99100-249250-499>499
Unit Price$21.30$19.00$17.90
In stock
Parallel data output format: 8-Bit Parallel ITU-R BT.656 with external HSync and VSync, No external power supply required, Compatible with Colibri Evaluation Board and Apalis Evaluation Board, -10°C to +60°C Temp, Range. Size: 60 x 50 x 9.4 mm.
Quantity>0
Unit Price$43.70
In stock
